Author Topic: Cannot add a File to a Use Case  (Read 3841 times)
michael.jeier
« on: October 02, 2008, 03:58:44 am »
I'm trying to add a File to a Use Case, but it isn't working though I get true, when I do an Update(). The File is simply not added to the properties when I check it manually on the Use Case. I also check before, whether it's the right Use Case - it is.  :-?
Here's the code snippet:
          // element is an EA.Element
            MessageBox.Show("Use Case name: " + element.Name
                    + " element ID: " + element.ElementID);
            element.Files.AddNew(strURL, "Web Address");
            bool updated = element.Update();
            element.Files.Refresh();
            element.Refresh();
            MessageBox.Show("updated: " + updated.ToString()); // true
Does someone see a mistake there??!? I really don't know what else to do.  :(  Thanks!
Regards, Michael
Takeshi K
    • Sparx Systems Japan
Re: Cannot add a File to a Use Case
« Reply #1 on: October 02, 2008, 06:28:14 am »
You need to call File.Update() method.
For example,
file = element.Files.AddNew(strURL, "Web Address");
file.Update();
Hope this helps.
t-kouno
t-kouno
michael.jeier
« Reply #2 on: October 03, 2008, 12:41:25 am »
yup - that worked! I knew I was missing something completely obvious!  :-/ Thanks a lot!!
Regards, Michael
