Author Topic: Multiple Models & SQL Server  (Read 4475 times)
TheCosmicTrickster
« on: November 13, 2009, 10:11:44 am »
Can anyone tell me if it is possible to store multiple EA models in a single SQL Server database?
We have several .EAP files that we want to migrate into a SQL Server-based repository.  However, it appears that you need one database per .EAP file (the documentation is not very clear on this point).
Re: Multiple Models & SQL Server
« Reply #1 on: November 13, 2009, 11:35:32 am »
Yes we do in an SQL Server based repository,
both created in the repository, and imported from previous .eap files.
« Reply #2 on: November 13, 2009, 12:01:20 pm »
both created in the repository, and imported from previous .EAP files.
I think we need to be careful about terms here...
A single MS SQL Server instance can hold multiple EA repositories (each one a SQL Server DB) each of which can hold multiple models (EA Package Roots).
Each .EAP file (An MS Access DB with a different file extension) is also a repository which can hold multiple models.
There are a number of mechanisms to transfer model data from a .EAP repository to a MSSQL repository.  The easiest, Tools|Data Management...|Project Transfer..., will clone one repository into another, "blowing away" the target.
So, if you started with 3 .EAP DBs; using this mechanism you would end up with 3 corresponding clone MSSQL DBs.
If, however, you want to aggregate multiple models (EA Root Packages) from multiple .EAP repositories into a single MSSQL repository, you need to use a different mechanism:  XMI package transput - output from one repository,input to the other.
Trickster, can you specify which scenario is the one you need?
PAolo
« Last Edit: November 13, 2009, 12:04:43 pm by PaoloFCantoni »
son-of-sargasso
« Reply #3 on: November 13, 2009, 09:54:21 pm »
transput
Wow, I thought for a moment you may have been too far into the Margaret River's of late.
Thank goodness for google though. http://en.wikipedia.org/wiki/ALGOL_68#transput:_Input_and_output
 ;D ;D ;D  (s'Friday, forgive me.)
« Reply #4 on: November 13, 2009, 10:52:11 pm »
transput
ALGOL68!   That brings back fond memories!
I actually wrote an in memory dynamic database in Algol68 at what used to be Caulfield Tech (in Melbourne).  You defined the model in what today we'd call a DSL and then entered the instances...
The first language that actually expanded my programing horizons...
I thought, I wrote, it did - minimal semantic gap!
The best non-OO language, in my opinion.  Much underrated - typically by people who'd never used it!
Thanks for reviving the memory!
TheCosmicTrickster
« Reply #5 on: November 23, 2009, 02:35:38 pm »
PAolo
We're aiming for the second one - multiple EAP repositories into a single MSSQL repository.  I'll get the user to experiment with XMI, see if he can get what we want.
Thanks for the help.
CT
