Author Topic: Can these be done with Transformations?  (Read 5112 times)
« on: December 17, 2009, 01:57:34 pm »
So I'm getting into Transformations.  So far, not a joyous exploration (see Browser and t_xref inconsistent after Transforms)
However, I'm sure it will all get sorted out.  The sample transformation I used in the above bug report was very simple (almost simplistic).
However, following my previous (unhappy) experience years ago with Code Template scripting and not wishing to waste a lot of my customers time I thought I'd list some of the things I'd like to do with transforms and if one or more kinds souls could indicate if it is (or should be) possible then that would allow me to better plan.   8-)
If some code snippets could be provided to help the general community that would be even better!  :)
So here's the list:
1)  We will want to make copies of structures and items but mark the copies read only ie locked (or secure them with security).  Can this be done in a transform?
2)  In these copies, we may want to change the linked diagram to navigate to on double-click.  Is is possible to access the diagram links via the transform?
3)  I believe we can interrogate the tagged values of the source and generate tagged values in the target via transforms - is this correct?
That's all for now... I'm sure I'll think of some more.
TIA,
Re: Can these be done with Transformations?
« Reply #1 on: December 17, 2009, 06:01:17 pm »
Paolo,
I hope I'm wrong, but I'm a little afraid you are one of the first users trying to really use the transformation for anything than a trivial case.
Anyway, I'm curious to the results of your experiments.
« Reply #2 on: December 18, 2009, 10:59:29 am »
No, transforms don't know anything about locking or security.  (Which is outside the model data itself.)
No, you don't have control over any aspect of the diagrams.
You can interrogate the source tagged values, not the ones that are generated.
« Reply #3 on: December 18, 2009, 12:23:26 pm »
Yes, I expected this, but no harm in asking.
Yes, I noticed NO mention of diagrams at all - which is reasonable.  Again, no harm in checking.
That's all I need.
Thanks for answering - saves a lot of fruitless investigation.
Oliver F.
    • Karl Storz homepage
« Reply #4 on: December 18, 2009, 09:25:56 pm »
Just note that while such things are not accomplishable via means on-board EA they can be done by calling an add-in from the templates via the EXEC_ADDIN macro.
I wrote a whole lot of those addin methods lately to support MDA transformation.
Oliver
« Reply #5 on: December 21, 2009, 09:00:36 am »
Actually no.  At the time the templates are being executed the target model doesn't exist (at least the first time), so you can't manipulate it via an add-in.
