Author Topic: UML Pattern: VB.NET + GoF Observer ? (MDG Link)  (Read 3983 times)
GillesMtl
« on: January 01, 2010, 02:11:15 am »
I just study EA 7.5 and test UML Pattern with MDG Link (MDG in trial version)
With a small VB.NET (2008) projet I realize a connexion into MDG Link
I go to Ressources of Project Browser and add Pattern Observer to Diagram. And generate code.
If I look code «ConcreteObseerver»:
note: I color text " text " where VB.NET error
Public Class ConcreteObserver
      Inherits Observer
      Private observerState As int
      Public m_ConcreteSubject As ConcreteSubject
      Public Sub Update()
            'observerState = subject->GetState()
      End Sub
End Class ' ConcreteObserver
I have 2 error:
Error      1
Class 'ConcreteObserver' must either be declared 'MustInherit' or override the following inherited 'MustOverride' member(s): ...
Error      2
Type 'int' is not defined.
I have impression EA+MDG+VB.NET is not a perfect mix  with GoF pattern... (?)  Do you have comment or hint
Re: UML Pattern: VB.NET + GoF Observer ? (MDG Link
« Reply #1 on: January 04, 2010, 03:54:55 pm »
What GoF pattern set are you using?  From memory we provide a C#, Java or Generic version.
I wouldn't expect any of these to compile when generated to Vb.Net.
