Author Topic: placing constraints across objects  (Read 3034 times)
paddler
« on: January 12, 2010, 04:31:31 am »
Hi
 I have a detailed business model comprised of Business Use Cases and Business Flows ( Activity Diagrams). I have used the "Constraints" tab on the Business Use Cases to capture business rules. I have a great report that can go through the repository and pull these out for me....
 So far, so good.
 Moving into Systems Analysis and System Use Cases I would like to have a means of linking those original business rules ( attached to those business use cases) up to User Requirements in the Solution Domain ( Use Cases, Functional/ Non functional requirements etc)
I can **see** the Constraints/ Business rules by clicking on a Business Use Case and selecting View -> Other Windows -> Element Browser . That's no problem....
 I cannot seem to drag these elements across to a System Use Case diagram or System Use Case
can anyone help me understand if constraints from one object can be associated to more than one OTHER object? I know that you can place the constraints on the diagrams themselves ( as opposed to the Business Use Cases) but this would make the diagrams ugly and hard to read,,,
 :o
"perfect is the enemy of good enough" - Voltaire
