Author Topic: Ahh! Replication Mess!  (Read 4365 times)
ebeb
« on: January 11, 2010, 09:57:14 pm »
I can't say nobody told me (thanks to Geert), but I was hoping for a normal use of eap replication I won't get into any trouble.
Now I know better.
I just created a replica and worked one day at home in a different package than the other employees. My package is version controlled so nobody could access. That's why I assumed that no conflicts should happen.
Now I know better.
This morning, I synced the DB and I got the cryptic "Resolve Conflicts" window. It told me that in table "package" the GUID "{A34534-343FE-..." has modified. Keep the current value 0 or overwrite by the value 3?  :-?
What the  f***? How should I know what that means? Just chose the latest value.
After that, one whole sub package I created with lots of requirements COMPLETELY DISAPPEARED! Two other packages I worked on were EMPTY!!! That's the worst case scenario! In both replica and master these packages were lost.  :o  :o  :o
I had to manually import the two empty packages contents from the xml file. I could not manage to recover the one that has disappeared.
The work from one day is lost!  :(
Now I know better.
To other EA users, I can only say this: Don't use replication!
To EA, I can only say this: Remove the feature from EA!
I already read, that its a Jet feature, not an EA, so if you can't provide a reasonable interface to that feature, don't provide it at all!  >:(
-Jan
Re: Ahh! Replication Mess!
« Reply #1 on: January 11, 2010, 10:44:31 pm »
I'm sorry, I know I shouldn't, but I can't resist:
[size=14]Told you so![/size]
PS. Jan, I really don't understand why you choose to use replication.
If you have version control you can checkout a package, take it home (offline) edit it, and when you come back in check it in again.
You already had all the tools to work in a distributed way with the version control... :-/
ebeb
« Reply #2 on: January 12, 2010, 12:10:09 am »
 :-[ Yes you did! Doh...
Because I though its the right way. I didn't think about using the xmi files... So what do exactly mean?
Using the EAP, checking out a package (which updates the xmi) and then what? Creating a new project and import / edit / export the xmi and then import it back in the EAP?
- Jan
« Reply #3 on: January 12, 2010, 12:27:31 am »
Jan,
With the EAP files its even easier.
take following steps:
  • Checkout the packages you want to edit at home (as you did before)
  • Make a copy of the (shared) eap file and put it on you laptop
  • At home start up EA and tell it you are working offline (Project/Version Control/Work Offline)
  • Open the eap file at home and edit as usual. (only the checked out parts ofcourse)
  • When back at the office just check the packages you have edited back in and do a "getlatest" on the shared eap file.
That should save you a lot of headaches.
« Reply #4 on: January 12, 2010, 08:45:47 am »
Not to lessen your experience in any way, but using version control with replication would be a fantastic way to cause conflicts and all sorts of bad behavior, since version control deletes a package and recreates it.
ebeb
« Reply #5 on: January 12, 2010, 08:10:41 pm »
really? so:
