Author Topic: Actor Stereotypes  (Read 9813 times)
zyx
Actor Stereotypes
« on: January 13, 2010, 12:26:44 am »
    I am trying to use a stereotype in an actor at the use case diagram, but when I define the stereotype it do not appear together the actor name. Someone knows how to do it?
Re: Actor Stereotypes
« Reply #1 on: January 13, 2010, 01:02:20 am »
If you want to show stereotypes on the actor you'll have to set the notation to rectangular.
Right Click/Advanced/Use Rectangular Notation
EA does not show stereotypes on "stickman" actor notations.
« Reply #2 on: January 13, 2010, 08:16:16 am »
[size=18]...[/size]
EA does not show stereotypes on "stick-man" actor notations.
Hi zxt,
While what Geert says is true (unfortunately).  You can make the stereotypes "visible" by rendering them with either colouration shape scripts.   See Settings|UML...|Stereotypes  This works even in "stick-man" notation.
« Last Edit: January 13, 2010, 08:18:50 am by PaoloFCantoni »
