Author Topic: problem with the java code generator  (Read 2972 times)
ericc
« on: January 23, 2010, 12:31:51 am »
Hallo,
i have a problem with the java code generator.
I use a "realize" connector between Class1 and Class2, and an "Generalize" connector between Class1 and Class3.
The generated code looks thus:
"public class Class1 extends Class2 Class3 { "
I became expect:
"public class Class1 extends Class3 implements Class3 { "
What can i do then ?
Re: problem with the java code generator
« Reply #1 on: January 23, 2010, 01:13:35 am »
Are you sure the Class3 is an interface?
In EA a class with stereotype <<interface>> is not the same as a "real" interface.
Try changing the type by selecting the element and then selecting the menu Element/Advanced/Change Type
ericc
« Reply #2 on: January 23, 2010, 01:24:53 am »
Thank you !
