Author Topic: Process boxes with 3 compartments?  (Read 3287 times)
Mike Dorey
« on: January 28, 2009, 11:58:16 pm »
Hi all
I am trying to create a diagram which contains process boxes with 3  compartments in them.  The first one would be the team carrying out the process, the middle one would be a brief description of the process including a unique ID, and bottom would be the name of the system where they are performing it.
E.g.
Logistics Team
1.1.2.6 Order
enters work pool
Order System
Does anyone know of a good way of doing this?   I was hoping to modify something in UML Activity or BPMN diagrams but I havent found a good solution yet.  Is there any way of making extra compartments available?
Thanks!
Takeshi K
    • Sparx Systems Japan
Re: Process boxes with 3 compartments?
« Reply #1 on: January 29, 2009, 07:05:23 pm »
The Add-in event 'EA_QueryAvailableCompartments' may be available.
(You need to create an Add-in to show your original compartment)
To know detail, see the help file.
If each compartment is simple, ShapeScript is useful.
Hope this helps,
t-kouno
neuron
« Reply #2 on: January 25, 2010, 08:19:55 pm »
how can I print compartment value in shapescript ?
neuron
Dima
« Reply #3 on: January 27, 2010, 06:53:30 am »
using: print("<insert property name here>")
