Author Topic: Element files, relative paths and version control.  (Read 3315 times)
bj
« on: January 28, 2010, 11:59:17 am »
I'm using EA 7.1 and am just starting to work with subversion version control using the private model outlined in the version control white paper.
I have several elements with files specified on the Files tab but they seem always to be stored with an absolute path. This prevents moving the project as a whole and makes the use of element files in a private model of version control nearly impossible (that I can see).
I have tried the Local Paths feature but the only file types available when adding a file are Local File and Web Address neither of these file types are directly supported in the Local Paths Type drop down. Even if I set up a Local Path for the file of the containing element type, the Apply Paths function has no effect.
So, is there a way to add files to elements using relative paths?
and
Are there any best practices for handling these external files using version control. I expect I can work something out if I can get the files stored as relative paths but would be interested in the suggestions or experience of others.
Re: Element files, relative paths and version cont
« Reply #1 on: January 28, 2010, 07:58:55 pm »
If I read the help topic about local paths it only mentions source code files.
Although the local paths are also used for Version Control (which is not documented in that topic) I don't think you can use it for element files.
What I would do is store the element files in a the same (or a subfolder of) directory used for your Version Control, and manage the check-in/out outside of EA.
If not all the users have the same working folder path, at leas they have a way of knowing where to find the file.
RoyC
  • Read The Help!
« Reply #2 on: January 29, 2010, 08:55:57 am »
In the Help for EA Release 8.0, we have added the following sentence to the Local Paths topic:
'As well as generating code and reverse engineering, you can use local paths in version control, developing XML schemas, and generating RTF and HTML reports.'
Best Regards, Roy
bj
« Reply #3 on: January 29, 2010, 10:39:38 am »
I was hoping for better news  :) but thanks for the reply.
Cheers,
~Blair
