Author Topic: Determine 'IsReturn' on a sequence connector?  (Read 5836 times)
Chris Tatem
« on: October 17, 2008, 03:18:32 am »
I am attempting to create sequence diagrams through the automation API.  I am "stringing" together several existing diagrams into one long diagram.  I have *most* of it working, but how can I tell if an existing connector (of type Sequence) has been "flagged" as IsReturn?  And then, how could I set that on a new Connector?  I can set that through the client here:
"Is Return checkbox in the Control Flow Type panel"
...I've tried subtype, EventFlafs, subtype and don't see it.
thanks
cwt
jkorman
Re: Determine 'IsReturn' on a sequence connector?
« Reply #1 on: October 17, 2008, 05:52:07 am »
try Connector.MiscData(3) (PDATA4)
  1 = isReturn
SubType appears to follow Lifecycle
Jim
Chris Tatem
« Reply #2 on: October 17, 2008, 08:02:28 am »
Thanks Jim, this correlates with the models that I'm reading!
Takeshi K
    • Sparx Systems Japan
« Reply #3 on: October 17, 2008, 03:32:24 pm »
For your information, you can get (and maybe update) the value by:
Connector.Properties.Item("IsReturn")
Hope this helps,
t-kouno
jkorman
« Reply #4 on: October 18, 2008, 12:13:37 am »
Excellent, thanks.......
I like that better.
Jim
Chris Tatem
« Reply #5 on: October 18, 2008, 01:35:00 am »
I liked the promise of this, but tried it and at least in the following (java) code snippet, didn't seem to work - unless I'm doing something wrong.
for (org.sparx.Property p : thisConnector.GetProperties()) {
      System.out.println("Property " + p.GetName() + "=" + p.GetValue() );
System.out.println("Misc " + thisConnector.MiscData(3));
org.sparx.Property isR = (thisConnector.GetProperties()).Item("IsReturn");
System.out.print("R" + isR.GetValue() + "?");
produces (for these two example connectors).  The IsReturn property is always null.  The second connector has isReturn selected on the diagram.
Property Name=getCustPayCard()
Property Type=Sequence
Property Kind=Call
Property IsReturn=null
Property IsAsync=null
Misc 0
Rnull?
Property Name=
Property Kind=Call
Misc 1
Rnull?
« Reply #6 on: October 18, 2008, 02:07:24 am »
What about the SubType attribute?
If that does not help, check the ConnectorEnd objects. [But I really don't think that's the problem.]
