Author Topic: Outer Class ?  (Read 5917 times)
meierch
  • Modeling we can!
Outer Class ?
« on: February 07, 2010, 02:58:40 am »
I try to generate some statements in the dot language used by GraphViz. I have a bunch of nested classes (classes with inner classes) - in other words a tree.
A
    B
    C
I need to transform this to
A -> B
A -> C
I have seen that I can check if a class is nested with %classIsNested%. But I don't know how to get the name of the outer class.
Any suggestion how to do this?
Christian
Regards
Christian
Makulik
Re: Outer Class ?
« Reply #1 on: February 08, 2010, 08:57:20 pm »
From http://www.sparxsystems.com/uml_tool_guide/sdk_for_enterprise_architect/fieldsubstitutionmacros.html
classQualNameThe Class name prefixed by its outer Classes. Class names are separated by double colons ( :: ).
May be you could use this, to do the trick?
Günther
meierch
  • Modeling we can!
Re: Outer Class ?
« Reply #2 on: February 09, 2010, 05:19:05 am »
Thanks ... I was also trying this. But how do I find the second occurance of '::' from the end?
Christian
Regards
Christian
Makulik
Re: Outer Class ?
« Reply #3 on: February 10, 2010, 01:57:04 am »
Hmm,
I see, to get the outer classes' bare class name (without namespace prefixes) s.th. like a find-from-end() macro would be needed (replace() to eliminate your actual classes' name + prefixed '::', finding and cutting aftwerwards) ; or that looping would need to be supported in the code generation templates.
I was missing fully fledged program control flow features in the code generation template language several times already :-( ...
WBR
Günther
meierch
  • Modeling we can!
Re: Outer Class ?
« Reply #4 on: February 10, 2010, 06:09:06 am »
Another idea was to pass the name of the outerclass as a template parameter when the inner classes are processed. But does alos not work ...
Regards
Christian
