Author Topic: copy/paste elements in a diagram (data model)  (Read 3454 times)
dermoritz
« on: February 15, 2010, 07:08:18 pm »
i'am new to ea so this might be a "stupid" question:
i' am modeling a database with many similar tables, each table with many similar columns. i thought i could make a template-like table an copy paste it as often i need it. but if i copy paste a table:
EA
This diagram already contains an instance of the element you are trying to paste.
 Currently, only one instance is supported, so you cannot paste the element here.
OK
occurs. so is the a way to make many tables of similar kind? probably by copying some parts in source?
thx in advance
Re: copy/paste elements in a diagram (data model)
« Reply #1 on: February 15, 2010, 07:15:15 pm »
Use rightclick/Paste as new
« Last Edit: February 15, 2010, 07:15:42 pm by Geert.Bellekens »
dermoritz
« Reply #2 on: February 15, 2010, 07:20:10 pm »
many thx! :-)
RoyC
  • Read The Help!
« Reply #3 on: February 16, 2010, 08:57:33 am »
You can also set up a Table element as a template in a templates package. See:
http://www.sparxsystems.com/uml_tool_guide/modeling_with_uml/using_element_templates.html
All your table elements will then be created with the same properties as the template.
Best Regards, Roy
dermoritz
« Reply #4 on: February 16, 2010, 06:50:25 pm »
good hint roy, thx!
