Author Topic: Exclude packages that are not approved in report  (Read 2623 times)
DerBerliner2010
« on: February 23, 2010, 08:40:25 pm »
Hi Guys,
how can i set up a report so that packages that are not in the status approved will be left out / excluded from the report????
I can't find a correct filter element for that?!?!  :(
Happy
Re: Exclude packages that are not approved in repo
« Reply #1 on: February 25, 2010, 07:44:30 pm »
a possible approach:
It should be possible to create a search via Manage Searches which shows all packages with the required state.
Then you select all packages in the search output and generate RTF documentation.
This should do the job.
Hope this helps.
Cheers,
H.
ZoeNord
« Reply #2 on: March 04, 2010, 05:50:42 pm »
Hi!
I've set package to be excluded from RTF report. right-click on a package, Documentation - RTF Options. How can I find these packages now? Visually there is no distinction from others. Is there a way to find them with the help of Search Model.
Thank you,
Zoja
