Author Topic: Should i create a calss to map 2 bridging DB table  (Read 2560 times)
peter king
« on: March 04, 2010, 11:32:04 am »
Hi friend,
i have received an ERD model of a database that has teh following reltionships between tables: tblAddresses, tblSupplierAddresses, tblSuppliers....
The relationship between the tables tblAddresses and tblSuppliers is M:N therefore tehy have added a bridging table tblSupplierAddresses..
when i create the UML diagram by looking at the ERD diagram, what shoul i create for this bedging entity, should i create a seperate class in teh UML as SupplierAddress to map to tblSupplierAddresses?
thanks
Re: Should i create a calss to map 2 bridging DB t
« Reply #1 on: March 04, 2010, 08:12:10 pm »
Peter,
It depends on what you are modelling.
Do you want a database model then yes create the linktables.
If you want to create a "logical" entity model then you should just create the m-n associations between the actual entities.
