Author Topic: Modifying AttributeDeclaration in code template  (Read 3200 times)
Aidyn
« on: March 05, 2010, 06:08:49 am »
I am trying to change the styling in generated C# code by modifying the AttributeDeclaration template. For example for class properties I want to change parenthesis, to change default style below
public string FirstName{
            get{
                  return _firstName;
            set{
                  _firstName = value;
to my own style
            get
                  return _firstName;
            set
                  _firstName = value;
How can I accomplish that?
My attempt to change default template
%if attStereotype == "property"%
{\n\t//read property\n\tget{;}\n\t//write property\n\tset{;}\n}
%endTemplate%
To
{\n\t//read property\n\tget\n\t{;}\n\t//write property\n\tset{;}\n}
%endTemplate%
Doesn’t produce expected result.
How can I circumvert this problem
Re: Modifying AttributeDeclaration in code templat
« Reply #1 on: March 05, 2010, 11:37:41 am »
You want the Operation Body stereotype override for property.  Not the attribute declaration template.
Aidyn
« Reply #2 on: March 06, 2010, 02:23:16 am »
Thanks for prompt response Simon. Could you please provide an example how to do it - any help is greatly appreciated!
« Reply #3 on: March 09, 2010, 08:33:55 am »
Have you tried changing
%if opTag:"writeonly" == ""%
$read="\tget{\n\t\treturn " + $att + ";\n\t}"
%endIf%
%if opTag:"readonly" == ""%
$write="\tset{\n\t\t" + $att + " = value;\n\t}"
%endIf%
to
$read="\tget\n\t{\n\t\treturn " + $att + ";\n\t}"
%endIf%
$write="\tset\n\t{\n\t\t" + $att + " = value;\n\t}"
%endIf%
« Last Edit: March 09, 2010, 08:34:16 am by simonm »
