Author Topic: how to team Collaboration at one EA project ?  (Read 5342 times)
wangcity
« on: March 09, 2010, 07:03:35 pm »
hi,
   I have a EA project, must team Collaboration, how to let everyone can edit one project at same time? thanks!
wangcity
Re: how to team Collaboration at one EA project ?
« Reply #1 on: March 09, 2010, 07:12:26 pm »
hi,
wangcity
Well, start by using "Collaboration" in the Search button above...  ;)
« Reply #2 on: March 09, 2010, 07:12:29 pm »
Wangcity,
If I understood you correctly you want to have multiple users be able to edit a model at the same time.
The simples solution is to put the eap file on a shared drive, but that will only work for a fairly limited number of users (eap file is MS-Access database)
If you require more then you can store the EA model on a real database. A number of databases are supported amongst wich MS SQL Server, MySQL, Oracle,...
One thing to be careful about is that no two users try to update an element at the same time. This might result in database locking errors and lost work. To avoid that you can use both the build in security feature to lock elements, or use an external Version Control system.
I usually recommend using VC as this also keeps a version history of the different changes in the model.
There are some whitepapers on the Sparx website that should give you some insight in how things work. I think one is called "deployment" and the other "version control".
« Last Edit: March 09, 2010, 07:12:49 pm by Geert.Bellekens »
wangcity
« Reply #3 on: March 09, 2010, 07:55:45 pm »
Wangcity,
what is VC ?  Can tell me more detail? thanks.
« Reply #4 on: March 09, 2010, 08:01:23 pm »
VC = Version Control
wangcity
« Reply #5 on: March 09, 2010, 08:06:27 pm »
Now, we try to use CVS as Version Control tools, but there is any merge/diff way for keeping everyone work on one version ?
« Reply #6 on: March 09, 2010, 08:11:10 pm »
VC integration in EA works with exclusive locks, so if one user has checked out a package then the other users can't edit at the same time.
In theory branching/merging is possible, but it you want to keep sane, don't do it :o
wangcity
« Reply #7 on: March 09, 2010, 08:18:22 pm »
ok, thanks a lot of!
wangcity
mennerrl
« Reply #8 on: March 11, 2010, 03:47:28 am »
One way is to Use Subversion. In EA help look for "Set up Subversion
philchudley
« Reply #9 on: March 11, 2010, 07:56:48 pm »
If you really do wish to have merging, then another option is to use EA's Baseline / Merging
The difference tool with baselines is more "user friendly" than that of Version Control clients
Cheers
Phil
Models are great!
