Author Topic: How to create a plotter file from a diagram  (Read 4686 times)
ebeb
« on: March 12, 2010, 10:11:40 pm »
Hi!
Recently, we created some really big diagrams and wanted to print/plot them. When we handed over a PDF, they told us it would better work with a PLT file and it would be cheaper ;)
So, is there any built-in way to do that or do you know any tool like a PLT printer driver to direct the data to a PLT file or any PDF to PLT converter?
If any of you has experience with that topic, please share your knowledge!
-Jan
beginner
Re: How to create a plotter file from a diagram
« Reply #1 on: March 12, 2010, 11:48:44 pm »
I once (20 years ago) wrote a couple of plotter drivers for HP. Very likely there is no way to create a vector file (which is needed for a plotter) from a bit image (contained in a PDF). So there are two options: a) use a large printer instead or b) create the plot file yourself. Though b) would be quite fun (and probably not too difficult as all vector information is stored in the database), I guess a) is cheaper on the short term. There might be a market for plotter files though.
b.
ebeb
« Reply #2 on: March 12, 2010, 11:52:42 pm »
Uhm...no. The PDF created using BullZip PDF printer from within EA creates a vector graphic as well. It's not a BMP!
So in that case, is it possible?
beginner
« Reply #3 on: March 14, 2010, 06:55:16 am »
Well, EA can produce wmf which is a vector format (if my mind doesn't fail me totally). It might be possible to convert that to a plotter file. You know: Google is your friend. Further: I do not have any experience in saving EA diagrams as wmf... Good luck.
b.
ebeb
« Reply #4 on: March 15, 2010, 06:36:02 pm »
WMF is vector based as well as EMF. even if you create a RTF, the diagrams in the RTF are all vector-based.
Wow, that's a good hint :) Nah, actually I searched intensively before I posted here. There is a lot PLT to PDF converters but no PDF to PLT and also no PLT virtual printers. That's why I asked here :)
Thanks anyway!
