Author Topic: Boundaries and contained objects  (Read 6507 times)
« on: March 22, 2010, 11:07:51 am »
When I move or drag a boundary containing entities all the entities that are fully contained maintain their position within the boundary.
When I align the boundary with another object all the entities that are fully contained are left behind.
Is this a bug or a feature,
methinks the former?
« Last Edit: March 22, 2010, 11:10:31 am by skiwi »
beginner
Re: Boundaries and contained objects
« Reply #1 on: March 22, 2010, 06:53:58 pm »
Metoo. But you likely have to accept it as a feature. Align just looks at the selected elements. The docking is one of the features added in a later release.
b.
« Reply #2 on: March 22, 2010, 07:54:07 pm »
b.
Skiwi was just talking about alignment, not docking.  But the real point is that although EA has pseudo-grouping, it doesn't have real groupng...  So we'll have to accept (as you say) that it's a feature.
beginner
« Reply #3 on: March 22, 2010, 08:51:57 pm »
As I understood skiwi wanted the boundary PLUS the docked elements (the pseudo group) to be moved to the alignment. Probably docked is not the correct word, but I do not know a better one.
b.
« Reply #4 on: March 22, 2010, 09:34:42 pm »
b.
The correct word is grouped.
Docked (as in a ship docked at a wharf) implies the edges are physically touching.  That's why Sparx upgraded the ability of elements to "dock" with each other.  In my experiments external docking seemed to work OK.  I didn't try internal "docking".  In Skiwi's example, if the internal elements were hard against the boundary, they might be considered internally docked and maybe they might have behaved differently.
« Reply #5 on: March 22, 2010, 09:39:44 pm »
The easiest solution to this problems is to align the "simple" objects with the "grouped" object. This way the "grouped" object doesn't move and the nested elemens stay neatly int the box.
(of course this only helps if you only have one "grouped" object to align)
beginner
« Reply #6 on: March 23, 2010, 08:45:05 pm »
Thanks Professor :-) Please keep in mind that I'm just a Kraut. (Why in heaven are Germans "Krauts" while Swedish aren't? Only in Sweden you get a free bag of sauerkraut with your pizza. Trying to order that in Germany will likely get you a kick-out from the Italian.)
b.
« Last Edit: March 23, 2010, 08:46:31 pm by beginner »
ebeb
« Reply #7 on: March 23, 2010, 09:54:19 pm »
I'd consider this as a bug. This aligment feature should use the same "move element" routine as it is used with the mouse.
PS.: Sauerkraut with Pizza??  :o
« Reply #8 on: March 24, 2010, 09:38:50 am »
Shouldn't that be coleslaw? Goes very well with pizza :)
ebeb
« Reply #9 on: March 24, 2010, 06:42:26 pm »
I think that's what he meant. AFAIK coleslaw is some kind of "Sauerkraut" salad, isn't it?
But still...on a pizza?  :o
beginner
« Reply #10 on: March 24, 2010, 06:49:49 pm »
Maybe, Neil. But when you wait long enough it becomes sauerkraut. It's more than 15 years since I worked in Sweden. So my memory might be wrong. (Thanks to Roy I now do know where the Kraut stems from.)
b.
« Last Edit: March 24, 2010, 06:51:01 pm by beginner »
« Reply #11 on: March 25, 2010, 06:17:53 am »
Reported as a bug
« Reply #12 on: March 25, 2010, 01:34:27 pm »
Feedback from bug report
Unfortunately this is an expected limitation of Align function.
Currently the Align only considers the elements that are selected.
A feature request has been submitted so that the inclusion of embedded elements (as you described) is considered for implementation in a future release.
In regard to moving a boundary without moving the embedded/contained elements, you can do this by holding the Alt key while dragging the boundary.
