Author Topic: How to disable member generation for iterfaces?  (Read 3277 times)
ebeb
« on: March 31, 2010, 02:26:28 am »
I'm still struggeling with code generation. Since now the transformation works (as far as I can see), I ran the code generation and imported it in NetBeans.
I saw that EA generates private member variables like e.g...
private ProtocolListener m_ProtocolListener;...if you have a directed association in the current class to (in this case) an interface called ProtocolListener.
But obviously, private methods are not allowed in interfaces. Actually, I don't want them at all.
So how can I disable it. I only found a way to do so for undirected associations.
Jan
« Last Edit: March 31, 2010, 02:27:40 am by ebeb »
Nizam Mohamed
Re: How to disable member generation for iterfaces
« Reply #1 on: March 31, 2010, 09:02:40 am »
In "Linked Attribute" Transformation Template(Java), add
%if linkAttAccess == "private"%
%endTemplate%
before
%Properties($name,$type)% call,
 which will avoid any get/set operation generation for associations with "private" scope.
if you'd just like to avoid them in the generated code,
in "Linked Attribute Declaration" code generation template (Ctrl + Shift + P)
replace
%CONVERT_SCOPE(linkAttAccess)%
with
$sAccess = %CONVERT_SCOPE(linkAttAccess)%
%if $sAccess == "private"%
%endTemplate%
or force "public" scope instead.('cos the getter and setters will refer to m_#VAR#, if generated through transformation)
« Last Edit: March 31, 2010, 09:33:09 am by nizammohamed »
