Author Topic: create full examplee  (Read 3629 times)
disname
« on: April 05, 2010, 06:55:17 pm »
please can any one help me  how create full application from use case and class diagram and generate code from sequence diagram
through simple example send to me at [email protected]
and thank for you.
« Last Edit: April 05, 2010, 06:57:15 pm by nedal »
Re: create full examplee
« Reply #1 on: April 06, 2010, 04:01:37 pm »
Why don't you start of with the example model provided by Sparx, and tell us where you runt into trouble.
I'm guessing that you will get better answers to precise questions then to expect someone to give you a full example.
Aaron B
« Reply #2 on: April 07, 2010, 03:30:44 pm »
As suggested by Geert, try looking at the EAExample.eap model provided with Enterprise Architect.  This model contains examples of Use Cases, Requirements and Class models, with relationships defined between them that can be traced (E.g. Use Case realizes Requirement, Class realizes Use Case).  The actual process of designing your project (writing use cases, etc) may be better addressed by gaining a better understanding of how to use UML in general.
For an example of behavioral code generation from a sequence diagram, browse to the Account class under Project Models > System Model > Implementation Model (PSM) > Java Model With Behaviors in the EAExample model.
disname
« Reply #3 on: April 07, 2010, 04:26:08 pm »
after i draw class diagram and sequence
i do not know what will do to generat coad from  sequence diagram
disname
« Reply #4 on: April 07, 2010, 05:46:44 pm »
please tell me
how generate code form sequence diagram
thanks for you
