Author Topic: Breaking the text of an use case  (Read 10220 times)
zyx
« on: April 15, 2010, 11:03:23 am »
   It is possible to force the break of the text of an use case in order to this text appear in two lines?
SomersetGraham
Re: Breaking the text of an use case
« Reply #1 on: April 15, 2010, 06:16:21 pm »
Hi
How do you mean?
If you enter the text for a Use case in the using the properties dialog you get a multi line editor to do so
Graham
Using V12
« Reply #2 on: April 15, 2010, 06:21:36 pm »
I'm guessing he means the name of the use case, and not the notes.
And no, I don't think it is possible to force the name to appear on two lines.
zyx
« Reply #3 on: April 16, 2010, 08:44:01 am »
Thank you for the help.
« Reply #4 on: April 16, 2010, 09:12:08 am »
The use case name will wrap at white space. This would require you to rename your use cases, but it's a common convention to name use cases with spaces between words.
