Author Topic: Import / Export of connectors / associations  (Read 5245 times)
Alex
« on: October 28, 2008, 01:10:41 am »
Are there some possibilities to import Connectors/Associations to Enterprise Architect?
Re: Import / Export of connectors / associations
« Reply #1 on: October 28, 2008, 09:33:17 am »
I'm not sure what you mean by "import" a connector. Could you please be more specific about your environment?
Are you transferring connectors between packages, or perhaps projects? If so you would probably have to transfer the end points (i.e. the things that the connectors connect) to make the transfer meaningful.
Alex
« Reply #2 on: October 31, 2008, 07:47:11 pm »
I mean the connector between packages. I have an Excel-list with applications and description of connection between these applications (InformationFlow from A to B). The problem is I can import applications to EA by CSV-Import, but not the associations/connectors.
There is possibility to export connections from EA to CSV-file separate from applications, but how does it work to import the connectors back to EA (separate or together with applications)? Is it generally possible? Do I need additional software?
