Author Topic: Parallel usage of EA 7.5 and 8 on a eap repository  (Read 6079 times)
meierch
  • Modeling we can!
« on: April 16, 2010, 04:32:03 am »
At work we have a bunch of models and quite a large EA user base. Is it possible to use EA7.5 and EA 8 in parallel on the same model? We actually work with replicas ...
Regards
Christian
Re: Parallel usage of EA 7.5 and 8 on a eap reposi
« Reply #1 on: April 16, 2010, 03:53:22 pm »
Christian,
I believe there should be no issues.
I'm currently working with the 8.0.855 where the other users are still on 7.5.850.
meierch
  • Modeling we can!
« Reply #2 on: April 16, 2010, 09:41:21 pm »
Thanks Geert
I think it would be good to have such information somewhere in the release notes.
Regards
Christian
beginner
« Reply #3 on: April 16, 2010, 09:51:11 pm »
The last time they had major issues with the database for a version change they did announce that. It was with the audit which once turned on would have fixed you to the new release but without you were able to live with both versions in parallel. This time there was no such announcement. Though it would be nice to read it explicitly in the release notes.
b.
Shawn Stepper
« Reply #4 on: April 20, 2010, 09:19:18 am »
When I tried this before I found that the spelling errors that 8.0 (Beta) flagged showed up as static colored text in 7.5. I filed a bug about it that was hopefully fixed in the final version, but you might want to check.
meierch
  • Modeling we can!
« Reply #5 on: April 24, 2010, 05:36:20 am »
Sparx support said:
Ideally it would be better to have all users running v8.0. However, there should be no major problems with running a mixed environment.
I hope this is of help.
Regards
Christian
