Author Topic: Setting Package Security  (Read 3309 times)
Andy B
« on: November 04, 2008, 12:12:35 am »
Is it possible to prgramatically set the package security and if so anyone got an example? Need to do this on a regular basis to apply the same security settings to packages that are added to a model. If you can't do it programatically then the only other option seems to be for someone to manually re-apply security settings when a new package is added - that is a bit limiting!
If you can set the security in this way is there a way to suppress the security and VC system login prompt as I would want this to be run on a schedule in the background not by a user needing to login as thta woudl defeta the object i.e. if a user had to login then they coudl manually set the security anyway.
Any help appreciated - ta
Andy
