Author Topic: Show Tagged Value in diagram  (Read 4306 times)
Shoko
« on: April 27, 2010, 06:40:19 pm »
I have one question:
Ist it possible to show a tagged value directly in a diagram?
I want to show the "Verdict" value for a TestCase.
Thanks!
SomersetGraham
Re: Show Tagged Value in diagram
« Reply #1 on: April 27, 2010, 06:53:23 pm »
Yes!
To show tag values for all elements use Elements tag on the Diagram properties dialog (access by right click on empty region of diagram or F5)
To show tag values for individual elements use the Feature Visibility dialog (access by right click on element or Ctrl+Shift+Y)
Graham
Using V12
« Reply #2 on: April 27, 2010, 06:53:34 pm »
Go to diagram properties/Elements and tick "tags"
Shoko
« Reply #3 on: April 27, 2010, 07:00:53 pm »
thanks for your quick replies!
Unfortunately this works for all other elements in my diagram, but not for the Test Cases.
I checked all Tagged Values checkboxes of the TestCase element feature visibility as well as in the diagram properties.
For Requirements the tagged values are shown, but I can't make the Tagged Values of the TestCase visible.
« Reply #4 on: April 27, 2010, 07:15:48 pm »
Best report it as a bug then.
I guess the custom shape for the testcase is [edit]not[/edit] build to show tagged values.
PS. Is this testcase standard EA or a third party MDG?
« Last Edit: April 27, 2010, 07:45:30 pm by Geert.Bellekens »
SomersetGraham
« Reply #5 on: April 27, 2010, 07:24:29 pm »
If you set the Test case element to be displayed using rectangular notation you will see the tagged values
Graham
Using V12
Shoko
« Reply #6 on: April 27, 2010, 07:51:15 pm »
Cool, thanks! Problem solved
