Author Topic: Version Control decisions  (Read 2878 times)
PetrPF
« on: May 05, 2010, 05:42:29 pm »
Hi guys,
I'd like to ask you two simple questions:
What are the criteria for choosing between
1/ Single shared model and Multiple private models?
2/ EAP file and RDBMS solution?
In general, what are the advantages and disadvantages of each solution and when to use which option?
Thank you.
Petr
Re: Version Control decisions
« Reply #1 on: May 05, 2010, 06:04:46 pm »
Petr,
Have you read the whitepapers on version control and deployment that are available on the sparx website? Those give you already some useful info.
Simply put:
- Single vs Multiple: go for single if possible. Only if you are working in a distributed way (lot of users having to work offline) then you could consider multiple (or a mix of both)
- EAP vs RDBMS: that is also simple. EAP is MS-Access and RDBMS is a real database. So just decide like you would for any other application when having to choose between MS-Access and a "real" database.
PetrPF
« Reply #2 on: May 05, 2010, 11:10:06 pm »
Thank you Geert.
I've obviously read the whitepaper, just wanted to know what the best real world practices are.
beginner
« Reply #3 on: May 05, 2010, 11:28:31 pm »
It depends, PetrPF. It depends. Your wolrd is not my current customer's world which isn't my previous customer's world. You'll probably need a trained consultant to decide what your needs are. Nothing off the shelf.
b.
