Author Topic: What MetaClass for diagram stereotypes?  (Read 6458 times)
mvinca
« on: May 05, 2010, 09:18:49 pm »
I want to create a stereotype that I can attach to any diagram. (Right now the pull down says "allocated" and "RequirementRelated".) However, I'm unable to figure out what MetaClass I extend in my UML Profile to do this. Can anyone help me out?
« Last Edit: May 05, 2010, 09:19:11 pm by mvinca »
Re: What Metaclass for diagram stereotypes?
« Reply #1 on: May 05, 2010, 10:21:08 pm »
AFAIK, you can't attach diagram stereotypes to profiles...
You just set the stereotype name in the diagram.
If Sparx or others confirm this...
Submit a Feature Request and tell us the name,
leaving a note here to say you've done it.
We users can then vote for it using a Feature Request with the same name[/color]
mvinca
Re: What MetaClass for diagram stereotypes?
« Reply #2 on: May 05, 2010, 10:24:50 pm »
I was afraid that might be the case. What you say is how I am currently doing it, but was hoping the pull down would read from the profile to ensure consistency.
However, it also makes sense that it might not be in the profile. A diagram really isn't a UML type right? Just a view into the UML Model?
« Reply #3 on: May 05, 2010, 10:31:24 pm »
Someone after my own heart...
Eventually even Geoffrey Sparx must get the message...
Even in UML, an Activity Diagram is an Activity (and EA supports this).
But EA isn't just a UML modelling tool...
It's a system design issue not a UML modelling tool issue.
« Reply #4 on: May 06, 2010, 09:17:18 am »
"Diagram" (I believe «allocated» and «RequirementRelated» both extend "<all>", which is the sledgehammer answer)
« Last Edit: May 06, 2010, 09:17:41 am by KP »
mvinca
« Reply #5 on: May 06, 2010, 09:34:52 am »
There is no "Diagram" in the metaclass list. There is "DiagramFrame", "DiagramGate" and "UMLDiagram". The first two didn't make sense and I already tried "UMLDiagram" and that didn't work.
« Reply #6 on: May 06, 2010, 09:51:43 am »
It doesn't matter: just create a class, name it "Diagram" and give it the «metaclass» stereotype...
mvinca
« Reply #7 on: May 06, 2010, 08:23:26 pm »
Oh, ok, cool. Could I use the same technique to extend a SysML stereotype, like <<block>>?
« Reply #8 on: May 07, 2010, 09:02:11 am »
Not currently possible. You would need to extend the same metaclass (in this case "Class") and apply both stereotypes («block» and your own) to an element.
