Author Topic: c++ code generation  (Read 2404 times)
gopher
c++ code generation
« on: May 08, 2010, 06:32:12 pm »
hi all
I'm a newbie to ea.
In my project class diagram, there are tiny objects (such as typedef or struct). when start code generate process, each "typedef" and "struct" always generate a single file. I wish generate some of them into a single file. how can i do?
SomersetGraham
Re: c++ code generation
« Reply #1 on: May 10, 2010, 05:14:29 pm »
Hi
Set the filename for the elements to be the same - F11 will display the code generation dialog from which you can select the filename
Graham
Using V12
gopher
« Reply #2 on: May 11, 2010, 01:50:30 am »
Thanks for ur reply, yes, that made it, all my tiny objects are generate in a single file  :)
