Author Topic: Using standard classes from Java in EA  (Read 3787 times)
akinarew
« on: May 13, 2010, 06:50:04 pm »
I would like to make my class extend class that exists in Java, for example Exception. Is there a way to import java classes into EA, so I have packages like java.util and then class Map, which I won't generate but it can be extended by my class.
I don't know how to explain it clearly. I want just generate code that would have all "import" to standard java classes.
How can I do that?
Re: Using standard classes from Java in EA
« Reply #1 on: May 14, 2010, 08:23:48 am »
You can import from the standard .jar files into EA.
