Author Topic: Can I copy a Web Style template for HTML report  (Read 3041 times)
Craig Westbury
« on: May 18, 2010, 02:22:13 pm »
Is is possible to make a copy of a Web Style template (in the resources tab) to create a new version of the same template?
I want to copy a highly modified template used for another model and tweak it, the only way I can see to do it now is to copy and paste the code for each section individually?
Craig
Re: Can I copy a Web Style template for HTML repor
« Reply #1 on: May 18, 2010, 09:13:53 pm »
Craig,
Can't you export the template, edit it (change its name), and import it again?
Craig Westbury
« Reply #2 on: May 19, 2010, 10:48:41 am »
Thanks Geert, that worked.
I used the Tools->Export Reference Data option and exported the "Templates - HTML Style" and "Templates - HTML Style Detail" tables.
A reasonable amount of Find and Replace and tidy up in the XML and I was able to re-import to create a new Web Template.
Cheers
Craig
