Author Topic: How show properties in the rectangule requirement?  (Read 4160 times)
Ernani Medeiros
« on: May 20, 2010, 12:58:39 am »
Please, someone could tell me how do I need to do to show in the second compartment of a requirement rectangle the properties which appears in the properties' window? It is not tagged values, I mean the standard properties.
Best Regards, :)
SomersetGraham
Re: How show properties in the rectangule requirem
« Reply #1 on: May 20, 2010, 01:14:50 am »
Hi
Right click on the element and select Feature Visibility on the context menu
Using V12
Ernani Medeiros
« Reply #2 on: May 20, 2010, 04:09:34 am »
Ok, thank you.
However, I have tried it before I posted. I am testing in EAExample, and I select a requirement, right click, Advanced, Use Rectangle Notation then it works fine.
After that -> right click, Feature Visibility, Show (in Attribute Visibility and/or Operation Visibility) it did not work.
Is there another thing that I can do to get what I want?
Best Regards,
SomersetGraham
« Reply #3 on: May 20, 2010, 06:06:21 pm »
Hi
Not really sure I know what you are trying to achieve.
I can change to rectangel notation and display the notes for example.
What are the features you want to show?
Using V12
Ernani Medeiros
« Reply #4 on: May 21, 2010, 12:53:40 am »
Oh, yes notes I can show too. However, beyond that I would like to show the properties that appear in the properties' window inside the second compartment of the rectangle.
Just like the SysML documentation demonstrated. Not only notes, do you see?
Is this possible?
I hope so and thank you anyway.
Ernani Medeiros
SomersetGraham
« Reply #5 on: May 21, 2010, 12:55:34 am »
AFAIK this is not possible, unless any other poster knows different :-[
Using V12
