Author Topic: How to reuse defined elements among projects?  (Read 3100 times)
safanth
« on: May 21, 2010, 04:47:54 pm »
I am new to using EA and try to achieve the following:
I'd like to define classes and datatypes and reuse those as predined classes/datatypes within other projects.
For example, I'd like to define a class named CMoneyValue, store that as a central reusable repository for any other project in EA. A new EA project could define a class and assign CMoneyValue to one of it's attributes.
How can I achieve this?
Simon
Re: How to reuse defined elements among projects?
« Reply #1 on: May 21, 2010, 04:53:01 pm »
Hi Simon,
You create a package to hold the common elements.  You can then export it from one repository and import it into another.
The import function includes the checkbox [  ] Strip GUIDs - this must not be marked if you wish to identify the same element in all the repositories in the same way...
safanth
« Reply #2 on: May 21, 2010, 05:05:27 pm »
Thank Paolo,
I tried it and I got that working indeed!
I do have a couple of follow up question though:
1) Is it possible to protect the imported definitions so they can be used to assign but not altered?
2) Is it possible to do the same for: Stereotypes?
3) Is it possible to do the smae for styles (colors)?
« Reply #3 on: May 21, 2010, 05:18:11 pm »
To protect the shared elements I've found it best to use integration with version control.
