Author Topic: How to show directions on class diagram?  (Read 4203 times)
Miguel Gonzalez
« on: May 24, 2010, 01:37:11 am »
On a named association, how do I show the direction it has to be read?
Like on figure 6 where it says 'fulfilled by'...
http://www.agilemodeling.com/style/classDiagram.htm#RelationshipGuidelines
Thank you.
Re: How to show directions on class diagram?
« Reply #1 on: May 24, 2010, 09:29:15 am »
Hi Miguel,
It IS tricky...
You need to select the label (with the Association Name) and then you can right-click to get the context menu.  Look for Direction>.
sargasso
« Reply #2 on: May 24, 2010, 09:53:50 pm »
Notwithstanding the above advice, let me just say "this".
"this"
re, your exemplary diagram, just HTF@! can an instance of an : : Order exist, if it hasn't already been delivered?
OMD how I hate half baked cr*p like that.
Enough, I'm going to get back in my casket.  Let s-o-s take care of it.
listen carefuly, my name is bruce
p.s. Scott's in the next crypt
« Last Edit: May 24, 2010, 09:57:53 pm by sargasso »
« Reply #3 on: May 24, 2010, 10:05:34 pm »
hi bruce (s-o-s)
Not withstanding you excellent point abut examples also being exemplars...
I'm not sure I understand your point.  Isn't the order the specification?  Therefore the order exists whether or not it's been delivered?
However, I note that in colloquial language we are often less rigorous with language than perhaps we might...
Which diagram are you complaining about?
Scott Ambler's usually pretty good at this stuff...   :)
sargasso
« Reply #4 on: May 24, 2010, 10:50:16 pm »
Paolo,
In Mr Ambler's figure 6, there exists a class, or classifier (I don't really care which) "Order" with an association to another class or classifier) "Delivery".  On this association there are four adornments, a <<name>> (meaningless, as the OP said, unless it has a "reading direction" ) and two cardinalities.  Of these, I beg to ask in the southernmost instance, doesn't this mean that:
If I instantiate a :: Delivery  , then it (by virtue of it's cardinality) it MUST belong to a :: Order. Fair enough, but if I substantiate a  :: Order , then diagramatically, I can only do so if there are >= 0 Delivery's that are already extant, somehow (_undefined).
Paolo, I'm not really sure where I'm going here, but.  There are some fundamental things, both in UML and in EA that need some serious and I mean serious (like M E N T H O I D S ) addressing.
as bl :) :-Xody always
bruce
Miguel Gonzalez
« Reply #5 on: May 25, 2010, 08:02:26 am »
Thank's Paolo, that helped.
Miguel.
« Reply #6 on: May 25, 2010, 10:07:09 am »
Paolo,
In Mr Ambler's figure 6, there exists a class ...
bruce
Oops...  (I plead I was "rushing out the door"....)
You are, of course, correct bruce.
Maybe Scott was enacting that non-sense from a long time ago in data modelling the: "optional tending to mandatory"?  I think you're of an age to recall that...
You are perfectly correct... These kinds of things need fixing...
There are better ways of handling that.
"Rigor is your friend"
