Author Topic: Change the name of the elements by Script  (Read 4017 times)
utilisateurEA
« on: May 25, 2010, 07:41:53 pm »
I’d like to modify by an Addin (a C# script) the name of all my elements. For instance Iwant to try to add ā€œ1ā€ at the end of these elements.
I tried something like this
while (i_nbElem < Coll.Count)
obj = Coll.GetAt(i_nbElem);
EA.Element All_Elem = (EA.Element)obj;
obj.All_Elem.Name.Insert(All_Elem.Name.Length, 1.Tostring() );
i_nbElem++;
But it doesn't change anything.
I think I change the name of something which is not the element of EA. But how can I change the name of the element in the model ?
Thank you
Re: Change the name of the elements by Script
« Reply #1 on: May 25, 2010, 07:47:01 pm »
you forgot to save the changes using update()
try this:
ALL_Elem.Update();
i_nbElem++;
utilisateurEA
« Reply #2 on: May 25, 2010, 08:17:46 pm »
It does'nt work...
Don't you think the problem is that I make my changes on a cast object whereas directly on my object ?
If I apply my change on my element does it implies automatically that the change will be on the object too ?
« Reply #3 on: May 25, 2010, 08:46:20 pm »
Maybe like this?
All_Elem.name =  obj.All_Elem.Name.Insert(All_Elem.Name.Length, 1.Tostring() );
ALL_Elem.Update();
i_nbElem++;
utilisateurEA
« Reply #4 on: May 25, 2010, 09:24:01 pm »
Now It works.
Thank you
« Last Edit: May 25, 2010, 09:26:11 pm by utilisateurEA »
