Author Topic: Change of class name not shown in attribute type  (Read 3700 times)
Michael Hafner
« on: May 25, 2010, 02:24:37 am »
Dear all,
v7.5; sometimes it works fine, most times it doesn't:
1. Create classes "Class_1", "Class_2"
2. Add attribute "attribute" to Class_1, set type to "Class_2"
3. Change name of Class_2 to "Class_3":
Problem: Class_1.attribute.type remains "Class_2". ("Select Attribute Type" shows Class_3, though.)
TrĂ­ed: "Save" or "reload" does not help.
Checked: No other classes with name "Class_2" in the model.
Did I miss something?
Best,
Michael
SomersetGraham
Re: Change of class name not shown in attribute ty
« Reply #1 on: May 25, 2010, 05:47:38 pm »
Hi Michael
I am using 8 but can repeat your observation.
It seems that if you enter the type of the attribute manually (ie type directly into the combo box) and then change the name it will not be updated.
However, if you use the 'picker' button to navigate to the required type then the name change is reflected.
Suggest you report a bug
Graham
Using V12
« Reply #2 on: May 26, 2010, 12:07:16 am »
Hi Folks,
You may find that this is by design...
I'll await Sparx's response but what Graham has observed actually seems reasonable.
However, it would help if it were documented...
