Author Topic: Relationship Matrix , Requirements and Instances  (Read 3905 times)
ChrisBD
« on: May 27, 2010, 09:34:56 pm »
Okay, using Version 8
If you have a number of requirements that are realized by ClassA.
You create an instance of ClassA => :ClassA
If you go to the relationship matrix it is possible to see that the requirements are realized by ClassA.
Should it be possible to see that these requirements are also met by :ClassA instance?
Re: Relationship Matrix , Requirements and Instanc
« Reply #1 on: May 28, 2010, 11:16:36 am »
[size=18]...[/size]
Hi Chris,
UML isn't very good in specifying such transitive relationships.  For example, it's my contention that if I specialize an item, I should inherit its stereotypes - but UML doesn't consider this.
I agree that a non-canonical (derived) relationship exists between the instance and the items related to the Classifier.
EA doesn't support this functionality which is understandable, in the circumstances.  You'll have to materialize the derived relationship yourself.
ChrisBD
« Reply #2 on: May 28, 2010, 06:27:19 pm »
It's not so much specialization that I was thinking of, but actual instance creation.
« Reply #3 on: May 28, 2010, 08:48:25 pm »
Hi Chris,
yes, I understand that but what I was trying to show is that this issue is one of a more general class of problem - transitive relationships.
