Author Topic: Using Parameterized Classes (Templates)  (Read 2061 times)
twarg
« on: June 05, 2010, 07:07:31 am »
Hi Folks,
I have a question about creating and using Parameterized Classes in EA8.
I want to create an Array as a parameterized class (template).   I believe I succeeded in doing that (create the class, under details tab select Templates->Type->Parameterized and I gave it 2 params...a BindType of type class [to bind a class to the template] and a Length of type int [initialize array length]).
My goal is to be able to create other classes with attributes of type Array<someType, someLength>.
My issue is, when you add an attribute of a class and want it to be of type say "Array<int,10>" (an integer array of length 10), EA does not seem to acknowledge the parameters in the parameterized class as part of the type.
EA finds the type Array, but not Array<BindType, Length>.
How do you instantiate an Array<int,10> from an Array parameterized class within EA?  :-/
twarg
