Author Topic: RTF output location  (Read 5174 times)
SomersetGraham
RTF output location
« on: June 07, 2010, 07:22:06 pm »
Hi
Does anyone else find this annoying?
When creating RTF documents the 'Output to file' location is retained from one invocation to the next. This means that I must remember to change the location for each document I create. If I forget then the original is overwritten.
Graham
Using V12
Re: RTF output location
« Reply #1 on: June 07, 2010, 07:32:05 pm »
Same thing with MDG profiles...  Here, though, the overwrites are more than just annoying...
If the profile isn't right, EA silently fails...
SomersetGraham
« Reply #2 on: June 07, 2010, 07:36:39 pm »
Great!!
Using V12
DavidL
« Reply #3 on: June 09, 2010, 01:11:52 am »
I have been using the configure resource for documents to hold the name of my template, name of the root package, and output document name for each report I generate. I setup the resource one time and generate the document from this RTF Document resource each time. (Right click on the resource and select "Generate Document")
Create a new configure resource for documents from the "Generate RTF Documentation" dialog by clicking on the "Resource Document" tab. The resource document is located by opening the resources tab:
View|Other Project Tools|Resources
followed by opening the Resource | Documents | RTF Documents resource.
This doesn't clear out the "output to file" field. It just helps error-proof the process of generating documents.
SomersetGraham
« Reply #4 on: June 09, 2010, 01:14:32 am »
Thanks - I'll give it a go
Using V12
