Author Topic: Listing Elements of a diagram  (Read 3740 times)
utilisateurEA
« on: June 08, 2010, 11:55:00 pm »
I would like to list all the elements used in a diagram with a script.
I tried EA.Diagram Diag and a Diag.DiagramObjects but it doesn't seem to be the right solution.
Do you know how I could list all the elements used in a diagram ?
Thank you
Re: Listing Elements of a diagram
« Reply #1 on: June 09, 2010, 09:29:04 am »
Define "all elements used in a diagram" and why .DiagramObjects doesn't do it for you...
utilisateurEA
« Reply #2 on: June 09, 2010, 05:13:38 pm »
By "all elements used in a diagram" I mean all the elements displayed on a diagram, like an interface, a port, an actor, a dependency,... anything which is displayed on my diagram.
.DiagramObjects doesn't fit to me because when I write my script, exactly when I write Diag.DiagramObjects. I have the choice between operations (like Delete, Equals, GetHashCode) but no property(except ObjectType). So I deduced it wasn't the right solution
« Last Edit: June 09, 2010, 05:14:05 pm by utilisateurEA »
« Reply #3 on: June 09, 2010, 10:00:10 pm »
Caveat - the following applies to the Automation Interface - it may not apply to the Scripting Interface.  (I don't use it as I do more complex stuff that isn't readily amenable to scripting).
Firstly, lines (such as Dependency) are not DiagramObjects - they are DiagramLinks.
Secondly, both DiagramObjects and DiagramLinks are collections and so you need to use Gets (such as GetAt() or GetByName())  to return the items of the collection.
