Author Topic: Valid Values for an Attribute...  (Read 6168 times)
AndyJ
  • It's only a model
« on: June 08, 2010, 01:30:25 pm »
Hi people,
I must be missing the obvious here...
I have a class that contains a number of attributes.
Two of the attributes can only contain a very limited set of valid values. Lets call them Source Reliability and Information Reliability.
In this case I'd expect to be able to record:
Source Reliability
{char 1}
{initial value: F}
{valid values: A B C D E F}
{char 1}
{initial value: 6}
{valid values: 1 2 3 4 5 6}
But so far have not been able to find somewhere to record this information against an attribute in a class.
I can see type and initial value, but cannot find a location for valid values...
Is it necessary to create a tagged value for each attribute where I wish to record this kind of information or am I missing an obvious dialog somewhere?
AndyJ
  • It's only a model
Re: Valid Values for an Attribute...
« Reply #1 on: June 08, 2010, 02:16:16 pm »
Digging further, I've found an attribute in the EA example project:
Rent:RentPerDay which contains a constraint:
AllowableValues{80,150,100}
However, even if I use that method, I haven't been able to find a way to make that (embedded) constraint visible to someone working with the model...
« Reply #2 on: June 08, 2010, 03:38:24 pm »
Andy,
What you are describing are enumerations.
Search the help file for enumeration.
sargasso
« Reply #3 on: June 08, 2010, 08:16:17 pm »
AndyJ,
If the "someones" working with the model can't or won't read a constraint then I can lend you a (reasonably) blunt bread-knife (or a chainsaw) that you could use to convince them that there is a wealth of information beyond the pretty pictures ... and they'd better dam'n well read 'em.
yours in the hope of a better future for all of that do describe constraints
bruce
AndyJ
  • It's only a model
« Reply #4 on: June 09, 2010, 09:42:33 am »
While I share your pain, it may be one of those theory vs. practice problems.
Developers are often under a lot of pressure, and it may be unreasonable to expect them to drill down to lower levels of a model to check for the existence of things, that 99.9999% of the time do not exist.
For this reason, I usually "externalise" constraints so that they appear on the class diagram, even if it is exported as a "pretty picture".
This also makes it easier to keep the users in the loop...
« Reply #5 on: June 09, 2010, 09:57:16 am »
If you put the constraint on the class rather than the attribute, the constraint can be shown on the diagram.
Alternatively, you can give the developers the documentation not the model - then the attribute level constraints won't be out of sight.
AndyJ
  • It's only a model
« Reply #6 on: June 10, 2010, 01:17:42 pm »
OK. If I am reading correctly... This is the UML way of describing the limited list of values for these two attributes.
Can anyone confirm this?
« Last Edit: June 10, 2010, 01:20:16 pm by novaphile »
« Reply #7 on: June 10, 2010, 02:39:09 pm »
Andy,
The attributes type's should not be char(1), but "Source Reliability" or "Information reliability".
The associations are not necessary.
(you can draw a dependency if you want to graphically show the relation)
AndyJ
  • It's only a model
« Reply #8 on: June 10, 2010, 02:55:01 pm »
OK.
Like this?
Thanks Geert,
Much appreciated.
Andy.
« Reply #9 on: June 10, 2010, 04:36:52 pm »
Yep, like that.
