Author Topic: set/configure  templates  (Read 4587 times)
tonywacu
« on: June 05, 2010, 01:26:54 am »
hello,
i have my own template of use case, can i configure EA so that it will generate documents according mine(template)?  please, can someone tell me wheather is possible or not, if possible how?
thanks in advance,
tony,
Re: set/configure  templates
« Reply #1 on: June 07, 2010, 03:54:03 pm »
Tony,
Yes that should be possible.
Look for RTF report in the help files.
tonywacu
« Reply #2 on: June 09, 2010, 06:28:15 pm »
Geert,
i ve looked at this, but i didn't find a way to
match the rtf report with my own template.
for exemple i would like to configure some thing like: put  "notes" of my use case in a column  of my template (my template is a table).
thanks you,
tony,
Makulik
« Reply #3 on: June 09, 2010, 06:57:04 pm »
Hi tony,
Go here: http://www.sparxsystems.com/resources/index.html and look for Whitepapers - Ritch-Text (RTF) Reporting
g.
SomersetGraham
« Reply #4 on: June 09, 2010, 07:00:53 pm »
Hi Tony
It is certainly possible to use table to organise data in the RTF generator, as Makulik says its in the manual butt he best way is to experiment a bit.
Using V12
pH
« Reply #5 on: June 17, 2010, 10:26:21 pm »
Document generation is pretty painful in EA. I really hope that templates can be directly created in Microwoft Word and also some conditional processing is allowed in the RTF Editor.
<a href="http://webuml.org"><img src="http://webuml.org/images/webuml-badge.png" alt="Set UML Free!" style="border-width:0"></a>
