Author Topic: How to generate Sequence diagram from the code  (Read 2705 times)
Rass
« on: June 21, 2010, 01:30:00 pm »
I already tried generating sequence diagram by debugging the code using EA.
1 - Is there any way to generate sequence diagram for a method in an imported code without debugging?
In EA7.5 when you right click on a method in project browser, there is an option "Generate Sequence Diagram [ctrl + shift + F6] but it doesn't work when i try it. Moreover, in EA8.0 this option is not there anymore .....
2 - is there any plug-in/update to make EA debugger support .net 4 ?
Tnx
