Author Topic: Import- connected elements from Excel  (Read 2793 times)
Kan
« on: June 30, 2010, 01:39:31 am »
I want to import a list of objects that are connected to objects via a simple association. What attributes do I include as col headings to ensure per line that Col A links to Col B via an association.Would I do two separate imports 1] for first object 2] for second object. What attribute defines the connect.
Re: Import- connected elements from Excel
« Reply #1 on: June 30, 2010, 12:56:18 pm »
Kan,
Out of the box that is not possible with EA, so you'll have to write something yourself to make it possible.
I've uploaded an excel importer to the community site that could be a starting point.
Kan
« Reply #2 on: June 30, 2010, 08:47:53 pm »
Hi Geert, I suspected as much but wanted to be sure I did not miss a trick. Any chance you could email me the "excel importer". My Sparx login is corrupt. Have logged a call but time is passing and I need to do a job of work. Many Thanks.
« Reply #3 on: June 30, 2010, 08:56:57 pm »
No problem, send me and email or pm with your email adress and I'll send you the excel file.
