Author Topic: managing lots of tables in DDL  (Read 3776 times)
Juan Pablo
« on: July 09, 2010, 02:15:42 pm »
hello.
i have a DDL with lost of tables. If i need print that, i have to use 6 papers. I need some suggestions about a better  way to organize (grouping or whatever) regarding relations between tables.
ie. If i have two tables which have a relation between them, then i could separate each one in a diferent diagram, and in a third one, add  both diagrams as a reference.
the problem here is that diagram have lost relation.
any suggestions?
thanks in advance
Re: managing lots of tables in DDL
« Reply #1 on: July 09, 2010, 02:32:22 pm »
Hi Juan Pablo,
You can create a diagram - place one table on it and then select the table and using <context menu>|Add...>Related elements to get EA to add the related tables.
Does that suit your needs?
Juan Pablo
« Reply #2 on: July 09, 2010, 02:48:55 pm »
hi Paolo, thanks for the fast reply.
My problem is that i have lots of tables, so i want to make an abstraction. for example, in place of show a caotic set of tables, order them in a kind of package.
Pack1 = 20 tables
pack2 = 30 tables
pack3 = 30 tables.
but in pack1 there is a table that have a relation whit a table in pack2, but it's not show in that way.
i think  a line from pack1 to pack2 should indicate relations.
« Reply #3 on: July 09, 2010, 04:01:25 pm »
Hi Juan Pablo,
There may be something I'm not getting...  Where did you get the set of table in EA from?  Reverse Engineering a database using EA or some other mechanism?
If using EA then if Table1 in Package1 has a FK Constraint with Table2 in Package2 then there will be FK Constraint visible between them if both tables are put on the same diagram.  Is this not what you are seeing?
I can understand your desire to abstract things a bit, but first we need to establish where the problem actually is.
