Author Topic: Insert bitmap in a RTF generated doc  (Read 3328 times)
utilisateurEA
« on: July 09, 2010, 05:28:25 pm »
I generate (with RTF templates) documents with images of my diagrams.
I would like my images to be in bitmap format Do you know if it is possible with RTF templates ?
Thank you
« Last Edit: July 09, 2010, 05:35:23 pm by utilisateurEA »
SomersetGraham
Re: Insert bitmap in a RTF generated doc
« Reply #1 on: July 09, 2010, 05:47:57 pm »
Hi
You can do this using the Advanced tab of the RTF Generation dialog - there is a diagram format setting.
This will only set it for the current run,however. to store this setting with the template you need to edit the template and select file->document options and look for the same setting.
Graham
Using V12
utilisateurEA
« Reply #2 on: July 09, 2010, 07:30:24 pm »
Thanks, I didn't see this parameter
