Author Topic: Entity Stereotype on Object Diagram  (Read 3394 times)
bdavisMorgan
« on: July 26, 2010, 06:00:58 pm »
Hello
I'm having a problem with maintaining a UML class symbol after defining an object as an entity stereotype on an object diagram. I drag a class symbol onto my object diagram and it looks fine. When I change the stereotype property to 'entity', the class symbol changes to an entity object symbol commonly used in analysis diagrams. What am I doing incorrectly?
Re: Entity Stereotype on Object Diagram
« Reply #1 on: July 26, 2010, 06:07:26 pm »
You doing nothing wrong.
What you are seeing is the standard EA implementation of the ECB pattern.
Have you tried disabling the alternate image for the entity stereotype in Settings/UML ? (I think it comes standard with a metafile definition)
« Reply #2 on: July 27, 2010, 08:47:58 am »
Unfortunately it doesn't, the drawing instructions are hard-coded in EA. Try switching off the option "Diagram > Properties > Elements > Use Stereotype Icons".
« Last Edit: July 27, 2010, 08:49:15 am by KP »
bdavisMorgan
« Reply #3 on: July 27, 2010, 11:06:37 am »
Thanks for the replies. KP's suggestion worked for me.
