Author Topic: Version 6.5 - Released (Build 803)  (Read 19497 times)
sparks
« on: January 23, 2007, 03:23:18 pm »
Release Notes for EA 6.5 Build 803
Resolved issue preventing deletion of objects from search window if the object has negative Object_ID.
Prevented unncessary error message when saving table operation with no column selected.
Add warning message when generated files set up read-only and then tried to re-script the tables from EA
Resolved shapescript issue filling or stroking paths containing bezier curves.
Resolved issue with hierarchy view and large depth setting.
Modified the Checkout operation using SCC version control, to Get the latest revision before the Checkout.
Fixed issue where XMI 2.1 import sometimes reversed connector direction.
Fixed issue where XMI 2.1 import sometimes reversed notelink Source and Target elements.
Fixed issue where XMI import sometimes lost the element, attribute, operation, operation parameter classifier.
Fixed issue where importing from XMI files containing empty operation and operation-parameter names caused errors in Oracle.
Resolved issue with implementation details documentation on MySQL.
