Author Topic: Reverse engineered elements - Any relative paths?  (Read 2796 times)
Alex_
« on: August 06, 2010, 11:33:51 pm »
Say, a team of developers need to be able to share diagram file thru version control system, and each developer needs to sync the reverse-engineered elements in the model, if he changes the API; then update the diagram, and commit.
The files in VCS are stored as:
src/
   main/
     java/
       ... (code)
   uml/
     my-file.EAP
And the diagrams of each project mostly contain classes which are at ../main/java
I've checked the "Settings->Local Files..." feature, but it does not support any relative (to .EAP-file) paths.
Is there some checkbox in EA to store links to source files in relative form rather that absolute?
Thanks!
« Last Edit: August 06, 2010, 11:34:33 pm by apanasovich »
Re: Reverse engineered elements - Any relative pat
« Reply #1 on: August 09, 2010, 08:35:48 am »
http://www.sparxsystems.com/enterprise_architect_user_guide/software_development/localpaths.html
PS.  Storing the eap file under version control is not recommended.
« Last Edit: August 09, 2010, 08:36:37 am by simonm »
