Author Topic: Filter for "difficulty" in a requirement?  (Read 2905 times)
Roland Ziegler
« on: August 19, 2010, 07:51:18 pm »
Hi there,
I'm trying to search a model (Model Search) for "Requirement" elements where the "Difficulty" element field is set to "High" (or any other value) - without success.
Searching for "Priority" set to "High" does work.
Any specific tricks here which I missed?
EA 8.0 build 861
Thank you
Re: Filter for "difficulty" in a requirement?
« Reply #1 on: August 19, 2010, 08:55:50 pm »
I'm guessing you are trying this using the search builder?
I always use the SQL search type.
The Difficulty is stored in pdata3
You can use something like this:
select o.ea_guid as CLASSGUID,o.object_type as CLASSTYPE,o.name as Name
from t_object o
where  o.Object_Type = 'Requirement'
and o.pdata3 like 'High'
and o.name like '<Search Term>'
sargasso
« Reply #2 on: August 19, 2010, 10:19:03 pm »
(( All "difficult" requirements are intentionally hidden. ))
b
Roland Ziegler
« Reply #3 on: August 20, 2010, 12:06:30 am »
That seems to be the case.  ;)
Actually I was hoping for a solution with the standard "Search Builder". However, the SQL query provided does the trick. Problem solved, technically speaking. Thanks a lot.
But how would you know that pdata3 stands for "Difficulty" (context dependent I guess)?
« Reply #4 on: August 20, 2010, 01:52:52 am »
Trial and error ::)
